We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProLite multi touchscreen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched.
Product Description | iiyama ProLite TF1734MC-B6X - LED monitor - 17" | Device Type | LED-backlit LCD monitor - 17" - touchscreen | Energy Class | Class E | Power Consumption (On mode) | 12.7 W | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 at 75 Hz | Pixel Pitch | 0.264 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Colour | Black, matte | Dimensions (WxDxH) | 36.9 cm x 4.75 cm x 30.7 cm | Weight | 3.6 kg | Compliant Standards | Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, CU, REACH SvHC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 17" |
Panel Type | TN |
Brightness w/touchscreen | 315 cd/m² |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 31.4 - 80 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Spanish, Japanese, Chinese |
Features | HDCP, OSD lock, HID Compliant, scratch-resistant, anti-fingerprint, glove touch mode |
Weight | 3.6 kg |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | DisplayPort , VGA , USB , HDMI |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | 90% light transmittance |
Cables Included | 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m |
Mounting Kit | Included |
Power | |
Power Consumption SDR (On mode) | 12.7 kWh/1000h |
Power Consumption (Typical) | 13 Watt |
Power Consumption Stand by | 2 Watt |
Power Consumption (Off Mode) | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
OS Required | Linux, Microsoft Windows |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
