iiyama ProLite TF1934MC-B5X 19" 1280x1024 14ms HDMI VGA...
iiyama ProLite TF1934MC-B5X 19" 1280x1024 14ms HDMI VGA DisplayPort LED Monitor
£528.63
Delivery:
Standard: 1-3 working days
Key features
  • IPS
  • Scratch resistance
  • Capacitive
  • Diagonal Size: 19in
  • Max Resolution: 1280 x 1024
  • Response Time: 14ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The ProLite TF1934MC multi-touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction and wide viewing angles. The touch function remains unaffected even if the glass is scratched.
Product Description iiyama ProLite TF1934MC-B5X - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19" - touchscreen
Features Touch-screen
Panel Type IPS
Aspect Ratio 5:4
Native Resolution SXGA 1280 x 1024
Pixel Pitch 0.294 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 14 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Colour Matte black
Dimensions (WxDxH) 41.6 cm x 4.65 cm x 34.4 cm
Weight 4.4 kg
Compliant Standards Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite TF1934M...
£528.63
