iiyama ProLite TF2215MC-B1 21.5" 1920x1080 14ms HDMI VGA...
iiyama ProLite TF2215MC-B1 21.5" 1920x1080 14ms HDMI VGA DisplayPort LED Monitor
£397.23
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • IP
  • Scratch resistance
  • Touch technology - capacitive
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 14ms
  • Speakers: [N/A]
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £400.72
Save £1.50
The ProLite TF2215MC-B1 (21.5 inch) uses PCAP touch technology and is built into an eye-catching bezel with edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch-resistance, making it perfect for kiosk and high use public facing applications.
Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation. For ease of integration, the TF2215MC-B1 comes equipped with external mounting brackets making it an ideal solution for kiosk integrators, industrial environments, control rooms and interactive multimedia.
Product Description iiyama ProLite TF2215MC-B1 - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5" - touchscreen
Energy Class Class A
Energy Consumption per Year 30 kWh
Power Consumption (On mode) 21 W
Features Touch-screen
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.24795 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 14 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Screen Coating 7H Hard Coating
Colour Black
Dimensions (WxDxH) 31.5 cm x 4.25 cm x 51.99 cm
Weight 4.4 kg
Compliant Standards DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite TF2215M...
£397.23
