iiyama ProLite TF2234MC-B3AGB 21.5" 1920 x 1080 8ms VGA...
iiyama ProLite TF2234MC-B3AGB 21.5" 1920 x 1080 8ms VGA DVI Monitor
Key features
  • IPS
  • Touch technology - capacitive
  • AG coating
  • Scratch resistance
Product codes
ProLite TF2234MC uses PCAP touch technology and is built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD Screen technology, it offers exceptional color performance and wide viewing angles. The higher brightness ensures crispy and clear images, even in a bright environment. In addition to the superb image quality, the screen is suitable for demanding environments. It comes with a rugged bezel and IP65 rating, meaning the monitor is dust and water resistant from the front. The Anti Glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. ProLite TF2234MC is the ideal screen for the kiosk integrators and a solution for Interactive Digital Signage, Instore Retail and Interactive Presentations.
iiyama ProLite TF2234MC-B3AGB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.247 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Screen Coating
Anti-glare, 6H Hard Coating
51.75 cm x 4.6 cm x 31.35 cm
4.4 kg
VCCI, VESA DPMS, cULus, TUV Bauart, IP65, CU, VESA DDC 2 B
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite TF2234M...
