iiyama ProLite TF2415MC-B1 23.8" 1920x1080 16ms HDMI VGA...
iiyama ProLite TF2415MC-B1 23.8" 1920x1080 16ms HDMI VGA DisplayPort LED Monitor
£551.77
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Open frame brackets
  • Touch technology - capacitive
  • Scratch resistance
Product codes
The ProLite TF2415MC-B1 (23.8 inch) uses PCAP touch technology and is built into an eye-catching bezel with edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch-resistance, making it perfect for kiosk and high use public facing applications. Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation. For ease of integration, the TF2415MC-B1 comes equipped with external mounting brackets making it an ideal solution for kiosk integrators, industrial environments, control rooms and interactive multimedia.
iiyama ProLite TF2415MC-B1 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8" - touchscreen
Touch-screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
16 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
7H Hard Coating
34.7 cm x 4.25 cm x 57.5 cm
5.8 kg
DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, CU
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite TF2415M...
£551.77
