iiyama ProLite TF2415MC-B1 23.8" 1920x1080 16ms HDMI VGA...
iiyama ProLite TF2415MC-B1 23.8" 1920x1080 16ms HDMI VGA DisplayPort LED Monitor
£548.90
Delivery:
Key features
  • Open frame brackets
  • Touch technology - capacitive
  • Scratch resistance
Product codes
The ProLite TF2415MC-B1 (23.8 inch) uses PCAP touch technology and is built into an eye-catching bezel with edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch-resistance, making it perfect for kiosk and high use public facing applications. Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation. For ease of integration, the TF2415MC-B1 comes equipped with external mounting brackets making it an ideal solution for kiosk integrators, industrial environments, control rooms and interactive multimedia.
Product Description iiyama ProLite TF2415MC-B1 - LED monitor - Full HD (1080p) - 23.8"
Device Type LED-backlit LCD monitor - 23.8" - touchscreen
Energy Class Class A
Energy Consumption per Year 31 kWh
Power Consumption (On mode) 21 W
Features Touch-screen
Panel Type VA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1
Response Time 16 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Screen Coating 7H Hard Coating
Colour Black
Dimensions (WxDxH) 34.7 cm x 4.25 cm x 57.5 cm
Weight 5.8 kg
Compliant Standards DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite TF2415M...
£548.90
