The ProLite TF2415MC-B2 uses PCAP touch technology and is built into a bezel with an edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch resistance, making it perfect for kiosk and public high use facing applications. Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation.
Product Description | iiyama ProLite TF2415MC-B2 - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" - touchscreen | Energy Class | Class F | Energy Consumption per Year | 36 kWh | Power Consumption (On mode) | 21.7 W | Features | Touch-screen | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.2745 mm | Brightness | 350 cd/m² | Contrast Ratio | 3000:1 | Response Time | 16 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Screen Coating | 7H Hard Coating | Colour | Black | Dimensions (WxDxH) | 34.7 cm x 4.25 cm x 57.5 cm | Weight | 5.8 kg | Compliant Standards | DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, CU | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | VA |
Brightness w/touchscreen | 315 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.4 - 82 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | English, French, Italian, Spanish, Dutch, Japanese, Chinese |
Features | Edge-to-edge glass, HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology, landscape mode, portrait mode, Face Up mode |
Colour | Black |
Weight | 5.8 kg |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , DisplayPort , HDMI , USB , Audio line-out |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Fingerprint-resistant coating, IP65 protection |
Included Accessories | Remote control |
Cables Included | 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m |
Power | |
Power Consumption SDR (On mode) | 21.7 kWh/1000h |
Power Consumption (Typical) | 25 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
OS Required | Microsoft Windows CE, Linux, Apple MacOS X, Microsoft Windows Vista / XP, Microsoft Windows 7 / 8 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
