iiyama ProLite TF2738MSC-B1 27" 1920x1080 5ms HDMI DVI D...
£617.02
38 in stock
Delivery:
Standard: 1-3 working days
Key features
  • AMVA+
  • Touch technology - capacitive
  • Open frame LFD
  • Scratch resistance
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI
Product codes
With Full HD resolution and Projective Capacitive 10-point touch technology, the ProLite TF2738MSC-B1 delivers seamless and accurate touch response. Featuring AMVA+ LED LCD screen technology, it offers exceptional color performance and wide viewing angles. Its rugged bezel with edge-to-edge glass makes it very suitable for applications like table top integration. Equipped with speakers, DVI, HDMI and DisplayPort inputs for multiple connecting possibilities. The ProLite TF2738MSC-B1 is an ideal screen for kiosk integrators and a perfect solution for interactive digital signage, instore retail, gaming and interactive presentations.
Product Description iiyama ProLite TF2738MSC-B1 - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27" - touchscreen
Energy Class Class A
Energy Consumption per Year 44 kWh
Panel Type A-MVA+
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.31125 mm
Brightness 300 cd/m²
Contrast Ratio 3000:1 / 12000000:1 (dynamic)
Response Time 12 ms (typical); 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, DisplayPort
Screen Coating 6H Hard Coating
Colour Black
Dimensions (WxDxH) 64.85 cm x 5 cm x 38.65 cm
Weight 7.7 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, DDC-2B, VESA DPMS, cULus, TUV Bauart, IPX1, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite TF2738M...
£617.02
