The ProLite TF3215MC-B1AG (31.5 inch) uses PCAP touch technology and is built into an eye-catching bezel with edge-to-edge anti-glare coated glass drastically reducing ambient reflections in high-brightness environments without compromising the sharpness and clarity of the image. The rugged bezel equipped with a foam seal finish supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front making it perfect for high use public facing applications. Landscape and portrait orientation ensures flexible mounting possibilities in almost any installation. The TF3215MC-B1AG is the ideal solution for kiosk integrators, industrial environments, control rooms and interactive multimedia.
Product Description | iiyama ProLite TF3215MC-B1AG - LED monitor - Full HD (1080p) - 31.5" | Device Type | LED-backlit LCD monitor - 31.5" - touchscreen | Energy Class | Class F | Power Consumption (On mode) | 31.6 W | Features | Touch-screen | Panel Type | A-MVA3 | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.3637 mm | Brightness | 500 cd/m² | Contrast Ratio | 3000:1 | Response Time | 8 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA | Screen Coating | 7H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 73.95 cm x 6.1 cm x 43.4 cm | Weight | 10.3 kg | Compliant Standards | Plug and Play, DDC-2B, CB, CU, REACH SvHC, IP65 front | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 31.5" |
Brightness w/touchscreen | 425 cd/m² |
Vertical Refresh Rate | 47 - 63 Hz |
Horizontal Refresh Rate | 30 - 68 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese |
Features | Cable management cover, HDCP, anti-glare, fanless cooling, landscape mode, portrait mode, 24/7 operating mode, TouchPro Pro-F Projected Capacitive (PCAP) technology, kiosk mode |
Colour | Black |
Weight | 10.3 kg |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , HDMI |
Mechanical | |
VESA Mounting Interface | 200 x 200 mm |
Miscellaneous | |
Features | 85% light transmittance, front IP65 protection |
Cables Included | 1 x HDMI cable , 1 x USB cable |
Mounting Kit | Included |
MTBF | 50,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 31.6 kWh/1000h |
Power Consumption (Typical) | 43 Watt |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Dimensions & Weight (Shipping) | |
Shipping Width | 89 cm |
Shipping Depth | 15.5 cm |
Shipping Height | 63 cm |
Shipping Weight | 12.85 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
