iiyama ProLite TF3215MC-B1AG 32" 1920x1080 8ms VGA HDMI...
£797.32
Delivery:
Notify me
Key features
  • Capacitive touch technology
  • Ball-drop-test proof
  • Through-glass touch
  • Diagonal Size: 31.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 8ms
  • Interfaces: HDMI, VGA (HD-15)
Product codes
The ProLite TF3215MC-B1AG (31.5 inch) uses PCAP touch technology and is built into an eye-catching bezel with edge-to-edge anti-glare coated glass drastically reducing ambient reflections in high-brightness environments without compromising the sharpness and clarity of the image. The rugged bezel equipped with a foam seal finish supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front making it perfect for high use public facing applications. Landscape and portrait orientation ensures flexible mounting possibilities in almost any installation. The TF3215MC-B1AG is the ideal solution for kiosk integrators, industrial environments, control rooms and interactive multimedia.
Product Description iiyama ProLite TF3215MC-B1AG - LED monitor - Full HD (1080p) - 31.5"
Device Type LED-backlit LCD monitor - 31.5" - touchscreen
Energy Class Class F
Power Consumption (On mode) 31.6 W
Features Touch-screen
Panel Type A-MVA3
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.3637 mm
Brightness 500 cd/m²
Contrast Ratio 3000:1
Response Time 8 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Screen Coating 7H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) 73.95 cm x 6.1 cm x 43.4 cm
Weight 10.3 kg
Compliant Standards Plug and Play, DDC-2B, CB, CU, REACH SvHC, IP65 front
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
iiyama ProLite TF3215MC-B1AG 32" 1920x1080 8ms VGA HDMI Touchscreen IPS LED Monitor
£797.32
Notify me
