iiyama ProLite X2380HS-B 23" 1920x1080 5ms VGA DVI-D HDM...
iiyama ProLite X2380HS-B 23" 1920x1080 5ms VGA DVI-D HDMI LED Monitor
Key features
  • IPS panel technology
  • Full HD
  • LED-backlit
  • ACR (Advanced Contrast Ratio)
  • HDMI (High-Definition Multimedia Interface)
  • OverDrive on/off
Product codes
ProLite X2380HS is a 23" LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles (178°/178°) and great response time (5 ms black-to-black). The ProLite X2380HS is full HD, has a more than 5mln:1 advanced contrast ratio and 250 cd/m2 brightness offering the user a clear and vivid image. An array of inputs including HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. The X2380HS also has the two integrated speakers and is VESA mountable. It will provide excellent performance for photographic design, web design, and standard office use and in multi-monitor environment.
iiyama ProLite X2380HS-1 - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
23.6 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
54.85 cm x 21.35 cm x 38.85 cm
5.8 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, TUV Bauart, TUV GM, TCO Displays 6.0, VCCI Class B
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite X2380HS...
