iiyama ProLite X2474HS-B1 24" 1920x1080 4ms VGA HDMI Dis...
iiyama ProLite X2474HS-B1 24" 1920x1080 4ms VGA HDMI DisplayPort LED Monitor
£105.20
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • VA matrix
  • Flicker-free + blue light
  • VESA mount compliance
  • Speakers and headphones
  • Advanced Contrast Ratio
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £108.69
Save £1.50
ProLite X2474HS - a 24" LED backlit LCD screen featuring VA panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Triple input configuration (VGA, HDMI, DisplayPort) assures compatibility with many platforms. A solid solution for both home and the office.
Product Description iiyama ProLite X2474HS-B2 - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class B
Energy Consumption per Year 39 kWh
Power Consumption (On mode) 26.8 W
Panel Type VA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.272 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1 / 80000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Matte
Colour Black
Dimensions (WxDxH) 54.6 cm x 19.95 cm x 40.3 cm
Weight 3.7 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards DDC-2B, DDC/CI, TUV Bauart, CU, REACH SvHC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite X2474HS...
£105.20
