iiyama Prolite X2485WS-B3 24" 1920x1200 VGA DisplayPort...
iiyama Prolite X2485WS-B3 24" 1920x1200 VGA DisplayPort LED Monitor
Key features
  • IPS technology
  • Blue light reducer
  • Speakers and headphones
Product codes
ProLite X2485WS features an IPS technology LED panel offering accurate and consistent color reproduction with wide viewing angles and fast response time. The ProLite X2485WS is a 16:10 monitor with 1920 x 1200 native screen resolution. An array of inputs including Display Port, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. It also has two integrated stereo speakers and is VESA mount compatible.
iiyama ProLite X2485WS-B3 - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Tilt
56.1 cm x 21.65 cm x 44.9 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, TCO Displays 6.0, VCCI Class B, CU
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama Prolite X2485WS...
