iiyama ProLite X2783HSU-B1 27" 1920x1080 AMVA+ LED Black...
iiyama ProLite X2783HSU-B1 27" 1920x1080 AMVA+ LED Black DP USB HUB
£165.67
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • AMVA+ panel technology
  • Flicker free + blue light
  • Speakers and headphones
  • Overdrive on / off
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
ProLite X2783HSU is a 27" LED backlit LCD screen featuring AMVA+ panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering 24-bit True Color and great performance for displaying black and white with the 3000:1 native contrast ratio, means that the Prolite X2783HSU will provide excellent performance for photographic, design and web-design.
Product Description iiyama ProLite X2783HSU-B3 - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 52 kWh
Power Consumption (On mode) 35.6 W
Features USB 2.0 hub
Panel Type A-MVA+
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.311 mm
Brightness 300 cd/m²
Contrast Ratio 3000:1 / 12000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Matte
Colour Black
Dimensions (WxDxH) - with stand 62.25 cm x 21.8 cm x 44.6 cm
Weight 4.4 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite X2783HS...
£165.67
