iiyama ProLite X2888HS-B2 - LED Monitor 28" 1920 x 1080...
iiyama ProLite X2888HS-B2 - LED Monitor 28" 1920 x 1080 VGA/DVI
£189.48
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • MVA technology
  • High color gamut
  • Flicker-free + blue light
  • Speakers and headphones
  • Diagonal Size: 28in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL) + 1 more
Product codes
Capable of displaying 95% of the NTSC color gamut, with the standard for an LCD screen being 72%, the ProLite X2888HS-B2 featuring VA technology offers beyond superb color reproduction. The sophisticated panel technology provides 24 bit True Color support and superior black and white display performance even if you are looking at the screen from the side. The X2888HS-B2 is an ideal screen for demanding users who settle for nothing but amazing image quality.
Product Description iiyama ProLite X2888HS-B2 - LED monitor - Full HD (1080p) - 28"
Device Type LED-backlit LCD monitor - 28"
Energy Class Class B
Energy Consumption per Year 60 kWh
Power Consumption (On mode) 41.4 W
Panel Type MVA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.32 mm
Brightness 300 cd/m²
Contrast Ratio 3000:1 / 12000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 66.3 cm x 24.2 cm x 46.35 cm
Weight 5.4 kg
Compliant Standards DDC-2B, VESA DPMS, TUV Bauart, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite X2888HS...
£189.48
