iiyama ProLite XB2283HS-B3 22" 1920X1080 4ms HDMI VGA DP...
iiyama ProLite XB2283HS-B3 22" 1920X1080 4ms HDMI VGA DP LED Monitor
£131.23
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Flicker free
  • Overdrive on/off
  • Speakers and headphones
  • Advanced contrast ratio
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The ProLite XB2283HS is an excellent Full HD LED-backlit monitor with resolution and VA panel technology guaranteeing accurate and consistent color reproduction with wide viewing angles. Triple input support ensures compatibility with the installed graphics card and embedded Notebook outputs. The XB2283HS is also equipped with two high quality stereo speakers.
The ergonomic stand offers height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. It is a perfect solution for education, local government, business and finance markets.
Product Description iiyama ProLite XB2283HS-B3 - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class A
Energy Consumption per Year 28 kWh
Power Consumption (On mode) 19 W
Panel Type VA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1 / 80000000:1 (dynamic)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) 50.5 cm x 23 cm x 37.15 cm
Weight 4.8 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite XB2283H...
£131.23
