The ProLite XB2283HS is an excellent Full HD LED-backlit monitor with resolution and VA panel technology guaranteeing accurate and consistent color reproduction with wide viewing angles. Triple input support ensures compatibility with the installed graphics card and embedded Notebook outputs. The XB2283HS is also equipped with two high quality stereo speakers.
The ergonomic stand offers height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. It is a perfect solution for education, local government, business and finance markets.
Product Description | iiyama ProLite XB2283HS-B3 - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class A | Energy Consumption per Year | 28 kWh | Power Consumption (On mode) | 19 W | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 80000000:1 (dynamic) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Black | Dimensions (WxDxH) | 50.5 cm x 23 cm x 37.15 cm | Weight | 4.8 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | VA |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese |
Features | HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology |
Colour | Black |
Weight | 4.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DisplayPort , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 21 Watt |
Environmental Standards | |
ENERGY STAR Certified | Yes |
