iiyama ProLite XB2380HS-B1 23" 1920x1080 5ms VGA DVI HDM...
iiyama ProLite XB2380HS-B1 23" 1920x1080 5ms VGA DVI HDMI Height Adjustable IPS LED Black Monitor
Key features
  • IPS panel technology
  • LED-backlit
  • ACR
  • Full HD
  • OverDrive on/off
  • Height adjustable stand
  • PIVOT
Product codes
ProLite XB2380HS is a 23" LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles (178°/178°) and great response time (5 ms black-to-black). An array of inputs including HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. The ergonomic stand offers 13 cm height adjustability, 360° rotation and portrait mode. The XB2380HS also has the two integrated speakers and is VESA mountable. It will provide excellent performance for photographic design, web design, standard office use and in multi-monitor environment.
Product Description iiyama ProLite XB2380HS - LED monitor - Full HD (1080p) - 23"
Device Type LED-backlit LCD monitor - 23"
Energy Class Class B
Energy Consumption per Year 35 kWh
Power Consumption (On mode) 23.6 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.2652 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) 54.85 cm x 24.45 cm x 41.55 cm
Weight 5.8 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, VCCI Class B ITE, DDC-2B, VESA DPMS, TCO Displays 5.0, TCO Displays 5.1, TCO Displays 5.2
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite XB2380H...
