iiyama ProLite XB3070WQS 30" 2560x1600 5ms VGA DVI HDMI...
iiyama ProLite XB3070WQS 30" 2560x1600 5ms VGA DVI HDMI DisplayPort IPS LED Monitor
Key features
  • High color gamut
  • Height adjustable stand
Product codes
The high color gamut iiyama XB3070WQS is the perfect choice for graphic and web-design. It features WQS (2560 x 1600) resolution offering huge workspace allowing users to display and manipulate multiple applications at the same time. The AH-IPS matrix guarantees high performance with accurate and consistent color reproduction, wide viewing angles and a fast response time. Optimal viewing comfort is guaranteed by the height adjustable stand.
iiyama ProLite XB3070WQS - LED monitor - 30"
LED-backlit LCD monitor - 30"
Energy Class
Class C
Energy Consumption per Year
104 kWh
Power Consumption (On mode)
71.3 W
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
QHD 2560 x 1600
Pixel Pitch
0.251 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Height, swivel, tilt
69.25 cm x 23 cm x 47.7 cm
7.4 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite XB3070W...
