We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProLite XB3288UHSU-B1 is a monitor capable of displaying 4 times more information than a Full HD screen. It will hence suit a massive range of applications requiring an above average viewable area, like desktop publishing, CAD/CAM drawing, data virtualization, photographic and web design. The VA panel technology offers exceptional color performance, high contrast and wide viewing angles.
Product Description | iiyama ProLite XB3288UHSU-B1 - LED monitor - 4K - 32" - HDR | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class G | Energy Consumption per Year | 65 kWh | Power Consumption (On mode) | 39.9 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.181 mm | Brightness | 300 cd/m² | Contrast Ratio | 3000:1 / 80000000:1 (dynamic) | Response Time | 3 ms | Colour Support | 1.07 billion colours | Colour Gamut | 95% NTSC | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) - with stand | 73 cm x 23 cm x 45.85 cm | Weight | 8.9 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | DDC/CI, PSE Mark, REACH, TUV Bauart, VCCI Class B, CU, DisplayPort 1.2, REACH SvHC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 32" |
Viewable Size | 31.5" |
Built-in Devices | USB 3.0 hub |
Panel Type | VA |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 135 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese |
Features | Picture by picture, HDCP, Eco-Mode, 10-bit gamma, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, i-Style Color, Picture-in-Picture |
Dimensions (WxDxH) | 73 cm x 23 cm x 45.85 cm - with stand |
Weight | 8.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 3 Watt |
Connectivity | |
Interfaces | 2 x HDMI (HDCP) , DisplayPort 1.2 , USB 3.0 upstream (Type B) , USB 3.0 downstream (Type A) , Headphones (mini-jack) , USB 3.0 downstream with Power Charging (Type A) |
Mechanical | |
Tilt Angle | -3/+22 |
Swivel Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 39.9 kWh/1000h |
Power Consumption HDR (On mode) | 52.1 kWh/1000h |
Power Consumption (Typical) | 44 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
