iiyama ProLite XU2290HS-B1 22" 1920x1080 5ms VGA DVI-D H...
iiyama ProLite XU2290HS-B1 22" 1920x1080 5ms VGA DVI-D HDMI LED Black Monitor with Speakers
£122.76
Select:
40 in stock
Delivery:
Standard: 1-3 working days
Key features
  • IPS panel technology
  • Full HD
  • LED-backlit
  • Advanced Contrast Ratio
  • Overdrive on/off
Product codes
ProLite XU2290HS is a 22" LED backlit LCD screen featuring IPS Panel technology which is considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles and fast response time. XU2290HS is Full HD, has an Advanced Contrast Ratio offering the user a clear and vivid image. The ProLite XU2290HS will provide excellent performance for photographic design, web design, standard office use and in multi-monitor environment.
Product Description iiyama ProLite XU2290HS-1 - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class B
Energy Consumption per Year 31 kWh
Power Consumption (On mode) 21 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 49.95 cm x 18 cm x 37.05 cm
Weight 3.7 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards DDC-2B, VESA DPMS, TUV Bauart, TCO Displays 6.0, VCCI Class B, EAC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite XU2290H...
£122.76
