iiyama ProLite XU2292HS-B1 22" 1920x1080 4ms VGA HDMI Di...
iiyama ProLite XU2292HS-B1 22" 1920x1080 4ms VGA HDMI DisplayPort IPS LED Monitor
£119.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • IPS technology
  • Flicker free
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £123.47
Save £1.50
The ProLite XU292HS featuring IPS technology guarantees accurate and consistent color reproduction with wide viewing angles. Triple input configuration (VGA, HDMI, DisplayPort) assures compatibility with many platforms.
Product Description iiyama ProLite XU2292HS-B1 - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class A
Energy Consumption per Year 24 kWh
Power Consumption (On mode) 16.5 W
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Matte
Colour Matte black
Dimensions (WxDxH) 48.85 cm x 18.7 cm x 37.6 cm
Weight 3.2 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards TUV GS, DDC-2B, PSE Mark, REACH, VCCI Class B, CU, REACH SvHC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite XU2292H...
£119.98
