We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProLite XUB2294HSU featuring VA panel technology guarantees accurate and consistent color reproduction with wide viewing angles. Triple input configuration (VGA, HDMI, DisplayPort) and a USB hub assure compatibility with many platforms.
Product Description | iiyama ProLite XU2294HSU-B1 - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class E | Energy Consumption per Year | 23 kWh | Power Consumption (On mode) | 16.5 W | Features | USB 2.0 hub | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz) | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 80000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC, 99% sRGB | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) - with stand | 48.85 cm x 18.7 cm x 37.6 cm | Weight | 3 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | TUV GS, DDC-2B, PSE Mark, REACH, VCCI Class B, CU, REACH SvHC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Built-in Devices | USB 2.0 hub |
Panel Type | VA |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese |
Features | Ultra Slim Design, HDCP, Eco-Mode, High Frame Rate Control (Hi-FRC), Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, 8-bit gamma, 72% NTSC colour gamut, 99% sRGB colour gamut |
Dimensions (WxDxH) | 48.85 cm x 18.7 cm x 37.6 cm - with stand |
Weight | 3 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DisplayPort , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , Headphones (mini-jack) |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16.5 kWh/1000h |
Power Consumption (Typical) | 19 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.26 Watt |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
