iiyama ProLite XU2390HS-B1 23" 1920x1080 5ms VGA DVI-D H...
iiyama ProLite XU2390HS-B1 23" 1920x1080 5ms VGA DVI-D HDMI LED Monitor
£116.36
Select:
49 in stock
Delivery:
Standard: 1-3 working days
Key features
  • IPS panel technology
  • Full HD
  • LED-backlit
  • ACR (Advanced Contrast Ratio)
  • HDMI (High-Definition Multimedia Interface)
  • OverDrive on/off
  • Diagonal Size: 23in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £119.85
Save £1.50
ProLite XU2390HS is a 23" LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles (178°/178°) and fast response time (5 ms black-to-black). XU2380HS is full HD, has a more than 5M:1 advanced contrast ratio and 250 cd/m2 brightness offering the user a clear and vivid image. The ProLite XU2390HS will provide excellent performance for photographic design, web design, standard office use and in multi-monitor environment. It is very suitable for multi-monitor Digtal Signage and office applications.
Product Description iiyama ProLite XU2390HS-1 - LED monitor - Full HD (1080p) - 23"
Device Type LED-backlit LCD monitor - 23"
Energy Class Class A
Energy Consumption per Year 31 kWh
Power Consumption (On mode) 21.4 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.265 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 53.25 cm x 18 cm x 38.75 cm
Weight 4 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards DDC-2B, VESA DPMS, TUV Bauart, VCCI Class B, EAC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite XU2390H...
£116.36
