iiyama ProLite XU2595WSU-B1 25" 1920x1200 5ms VGA HDMI D...
iiyama ProLite XU2595WSU-B1 25" 1920x1200 5ms VGA HDMI DisplayPort IPS LED Monitor
£179.64
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • IPS
  • Flicker-free + blue light
  • Speakers and headphones
  • ACR
  • VESA
  • Diagonal Size: 25in
  • Max Resolution: 1920 x 1200
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £183.13
Save £1.50
Providing excellent picture performance, the ProLite XU2595WSU is a great choice for office applications, graphics applications and CAD applications. The monitor features an IPS Technology LED panel offering 1920 x 1200 native resolution with accurate color reproduction and wide viewing angles. The blue light reducer function and flicker-free LED's helps to significantly limit eye fatigue typically caused by working with a computer screen.
Product Description iiyama ProLite XU2595WSU-B1 - LED monitor - 25"
Device Type LED-backlit LCD monitor - 25"
Energy Class Class A
Adaptive-Sync Technology AMD FreeSync
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution WUXGA 1920 x 1200 at 75 Hz
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours (8-bit)
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Matte
Colour Black
Dimensions (WxDxH) 54.65 cm x 18 cm x 43.85 cm
Weight 3.9 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards CB, RoHS, WEEE, TUV Bauart, EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite XU2595W...
£179.64
