iiyama ProLite XUB2292HS-B1 22" 1920x1080 4ms VGA HDMI D...
iiyama ProLite XUB2292HS-B1 22" 1920x1080 4ms VGA HDMI DisplayPort IPS LED Monitor
£124.64
Delivery:
Notify me
Key features
  • IPS technology
  • Height-adjustable stand
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Stylish edge-to-edge design makes the ProLite XUB2292HS perfect for multi-monitor setups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles. High contrast and brightness values mean the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences.
Product Description iiyama ProLite XUB2292HS-B1 - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class E
Energy Consumption per Year 24 kWh
Power Consumption (On mode) 13.7 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Voltage AC 120/230 V (50 - 60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 48.85 cm x 21 cm x 48.2 cm
Weight 4.8 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards TUV GS, PSE Mark, VCCI Class B, CU, REACH SvHC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£124.64
Notify me
