iiyama ProLite XUB2395WSU-B1 23" 1920x1200 4ms VGA HDMI...
iiyama ProLite XUB2395WSU-B1 23" 1920x1200 4ms VGA HDMI DisplayPort IPS LED Monitor
£159.99
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 22.5in
  • Max Resolution: 1920 x 1200
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The demanding data and application heavy world needs a display that creates a more productive work place. The height adjustable stand with pivot function allows you to easily adjust the monitor position to your preferences and the IPS panel technology assures accurate and consistent color reproduction with wide viewing angles.
Product Description iiyama ProLite XUB2395WSU-B1 - LED monitor - 22.5"
Device Type LED-backlit LCD monitor - 22.5"
Energy Class Class E
Power Consumption (On mode) 17.4 W
Adaptive-Sync Technology AMD FreeSync
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution WUXGA 1920 x 1200 at 75 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 4 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Matte
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) 49.9 cm x 23 cm x 38.5 cm
Weight 5.4 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards RoHS, WEEE, TUV Bauart
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£159.99
