The demanding data and application heavy world needs a display that creates a more productive work place. The height adjustable stand with pivot function allows you to easily adjust the monitor position to your preferences and the IPS panel technology assures accurate and consistent color reproduction with wide viewing angles.
Product Description | iiyama ProLite XUB2395WSU-B1 - LED monitor - 22.5" | Device Type | LED-backlit LCD monitor - 22.5" | Energy Class | Class E | Power Consumption (On mode) | 17.4 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 2.0 hub | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | WUXGA 1920 x 1200 at 75 Hz | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 1.07 billion colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 49.9 cm x 23 cm x 38.5 cm | Weight | 5.4 kg | Environmental Standards | TCO Certified Displays 7, ENERGY STAR Qualified | Compliant Standards | RoHS, WEEE, TUV Bauart | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22.5" |
Built-in Devices | USB 2.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 89 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Polish, Russian, Dutch, Japanese |
Features | Ultra Slim Design, HDCP, Flicker Free technology, Blue Light Filter technology |
Colour | Black |
Weight | 5.4 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DisplayPort , 2 x USB 2.0 , Headphone input |
Mechanical | |
Tilt Angle | -4/+20 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB cable , 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 17.4 kWh/1000h |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 0.5 Watt |
Environmental Standards | |
TCO Certified | TCO Certified Displays 7 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
