iiyama Prolite XUB2492HS-B1 24" HDMI DP DVI IPS Black Mo...
iiyama Prolite XUB2492HS-B1 24" HDMI DP DVI IPS Black Monitor
£152.98
Select:
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • IPS technology
  • Ultra Slim Line
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Stylish edge-to-edge design makes the ProLite XUB2492HSU perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles. High contrast and brightness values mean the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences. It is a great choice for both multi-monitor Digital Signage and office applications.
Product Description iiyama ProLite XUB2492HSU-B1 - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A+
Energy Consumption per Year 26 kWh
Power Consumption (On mode) 17.5 W
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) 53.95 cm x 23 cm x 37.6 cm
Weight 5.4 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama Prolite XUB2492...
£152.98
