We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Stylish edge-to-edge design makes the ProLite XU2493HSU perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles. High contrast and brightness values mean the monitor will provide excellent performance for photographic and web design.
Product Description | iiyama ProLite XUB2493HS-B4 - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class E | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz) | Pixel Pitch | 0.275 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC, 96% sRGB | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Matte | Voltage | AC 100-240 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) | 53.95 cm x 21 cm x 37.3 cm | Weight | 5.7 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | DDC/CI, RoHS, WEEE, PSE Mark, REACH, TUV Bauart, ERP, VCCI Class B, EAC, REACH SvHC, UKCA | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Panel Type | IPS |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese |
Features | HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), edge-to-edge glass, X-Res Technology, i-Style Color, Adaptive-Sync technology, Blue Light Reducer Function |
Weight | 5.7 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DisplayPort , Headphones |
Mechanical | |
Tilt Angle | -5/22 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16 kWh/1000h |
Power Consumption (Typical) | 16 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Dimensions & Weight (Shipping) | |
Shipping Width | 67 cm |
Shipping Depth | 17 cm |
Shipping Height | 38.9 cm |
Shipping Weight | 6.4 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
