The X-series monitors come with top-class features and deliver best-in-class performance. Incorporating the latest IPS or AMVA technology along with multiple inputs, the displays offer supreme color performance and optimum compatibility across a broad range of multi-media devices. They assure consistent and accurate color reproduction from all viewing angles. The image is clear and blur-free as the panels can process high speed signals without data loss. The X-series monitors are a huge hit with demanding users like photographers, graphic artists and DTP professionals.
Product Description | iiyama ProLite XUB2595WSU-B1 - LED monitor - Full HD (1080p) - 25" | Device Type | LED-backlit LCD monitor - 25" | Energy Class | Class F | Power Consumption (On mode) | 20.5 W | Features | USB 2.0 hub | Panel Type | AH-IPS | Native Resolution | Full HD (1080p) 1920 x 1200 at 75 Hz | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation) | Colour | Matte black | Dimensions (WxDxH) | 54.65 cm x 39.9 cm x 52.9 cm | Weight | 5.2 kg | Environmental Standards | TCO Certified Displays 7, ENERGY STAR Qualified | Compliant Standards | VESA DPMS, CB, TUV Bauart, EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 25" |
Built-in Devices | USB 2.0 hub |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Ultra Slim Design, Flicker Free technology |
Weight | 5.2 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , Headphones (mini-jack) |
Mechanical | |
Rotation Angle | 180 |
Height Adjustment | 90 mm |
Miscellaneous | |
Cables Included | 1 x DisplayPort cable , 1 x USB cable |
Power | |
Power Consumption SDR (On mode) | 20.5 kWh/1000h |
Power Consumption (Typical) | 28 Watt |
Power Consumption Stand by | 0.5 Watt |
Environmental Standards | |
TCO Certified | TCO Certified Displays 7 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
