iiyama ProLite XUB2790HS-B1 27" 1920x1080 5ms VGA DVI-D...
iiyama ProLite XUB2790HS-B1 27" 1920x1080 5ms VGA DVI-D HDMI LED Monitor
£209.12
Select:
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • IPS panel technology
  • Full HD
  • LED-backlit
  • Advanced contrast ratio
  • Pivot
  • Height adjustable stand
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
ProLite XUB2790HS is a 27" LED monitor with latest AH-IPS Panel technology considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles and a fast response time. A truly ergonomic stand including pivot function makes the XUB2790HS an excellent choice for photographic design, web design, standard office use. It’s the perfect choice for multi-monitor applications.
Product Description iiyama ProLite XUB2790HS-1 - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Energy Consumption per Year 40 kWh
Power Consumption (On mode) 27.1 W
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.311 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) 62.25 cm x 23 cm x 43.3 cm
Weight 5.4 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards DDC-2B, VESA DPMS, TUV Bauart, TCO Displays 6.0, VCCI Class B, EAC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite XUB2790...
£209.12
