iiyama ProLite XUB2792QSU-W1 27" 2560x1440 5ms HDMI DVI...
iiyama ProLite XUB2792QSU-W1 27" 2560x1440 5ms HDMI DVI DP LED Monitor
£277.63
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • WQHD resolution
  • IPS technology
  • Height-adjustable stand
  • Flicker-free monitor
  • Speakers and headphones
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £281.12
Save £1.50
Stylish ultra-flat front design makes the ProLite XUB2792QSU perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles and the WQHD resolution means the XUB2792QSU can accommodate more information on the screen than a Full HD display. High contrast and brightness values guarantee the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences. It is a great choice for both multi-monitor digital signage and office applications.
Product Description iiyama ProLite XUB2792QSU-W1 - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 50 kWh
Power Consumption (On mode) 34.4 W
Adaptive-Sync Technology AMD FreeSync
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 2560 x 1440
Pixel Pitch 0.233 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, DVI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Matte
Colour White
Dimensions (WxDxH) 61.1 cm x 23 cm x 39.7 cm
Weight 6.1 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards TUV GS, DDC-2B, VESA DPMS, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite XUB2792...
£277.63
