iiyama ProLite XUB2792UHSU-B1 27" 3840x2160 4ms HDMI DV...
iiyama ProLite XUB2792UHSU-B1 27" 3840x2160 4ms  HDMI DVI DisplayPort 4K LED Monitor
£352.77
Delivery:
Standard: 1-3 working days
Key features
  • IPS technology
  • UHD resolution
  • Flicker-free + blue light
  • HAS + pivot
  • Speakers and headphones
  • Diagonal Size: 27in
  • Max Resolution: 3840 x 2160
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £356.26
Save £1.50
Stylish ultra-flat front design and 4K resolution make the ProLite XUB2792UHSU a perfect addition to the desk of any graphic designer. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles and the 4K (3840 x 2160) resolution means the XUB2792UHSU can accommodate 4 times more information on the screen than a Full HD display. High contrast and brightness values guarantee the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences.
Product Description iiyama ProLite LED monitor - 4K - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 49 kWh
Power Consumption (On mode) 33.8 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz, DVI: 30 Hz)
Pixel Pitch 0.16 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 4 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, DVI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Matte
Colour Black
Dimensions (WxDxH) 61.4 cm x 23 cm x 39.7 cm
Weight 6.4 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, PSE Mark, VCCI Class B, CU, VESA DDC 2 B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite XUB2792...
£352.77
