ProLite XUB3493WQSU offers accurate and consistent color reproduction with wide viewing angles and a fast response time. UWQHD resolution offers an ultra-wide (21:9) viewable area. The large amount of space and good pixel density offered by the size and resolution of this screen provide great potential on the desktop. Very suitable for those who want to use side-by-side applications, watch a movie shot in widescreen format or enrich their gaming experience.
Product Description | iiyama ProLite XUB3493WQSU-B1 - LED monitor - 34" - HDR | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class G | Power Consumption (On mode) | 39.6 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Panel Type | ADS-IPS | Aspect Ratio | 21:9 | Native Resolution | UWQHD 3440 x 1440 at 75 Hz | Pixel Pitch | 0.233 mm | Brightness | 400 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Matte, Haze 25% | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) | 81.7 cm x 23 cm x 41.5 cm | Weight | 9.5 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, PSE Mark, TUV Bauart, DDC-2B/CI, VCCI Class B, EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 34" |
Built-in Devices | USB 3.0 hub |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 115 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese |
Features | Picture in picture, HDCP, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color |
Weight | 9.5 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Headphones , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) |
Mechanical | |
Tilt Angle | -3/+22 |
Swivel Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable , 1 x HDMI cable , 1 x USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 39.6 kWh/1000h |
Power Consumption HDR (On mode) | 58.2 kWh/1000h |
Power Consumption (Typical) | 43 Watt |
Power Consumption Stand by | 0.5 Watt |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
