iiyama ProLiteXUB2390HS-B1 23" 1920x1080 5ms VGA DVI-D H...
iiyama ProLiteXUB2390HS-B1 23" 1920x1080 5ms VGA DVI-D HDMI LED IPS Monitor
£127.71
21 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 23in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £131.20
Save £1.50
ProLite XUB2390HS is a 23" LED monitor with latest IPS Panel technology considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles and a fast response time. A truly ergonomic stand including pivot function makes the XUB2390HS an excellent choice for photographic design, web design, standard office use. It’s the perfect choice for multi-monitor applications.
Product Description iiyama ProLite XUB2390HS-B1 - LED monitor - Full HD (1080p) - 23"
Device Type LED-backlit LCD monitor - 23"
Energy Class Class A
Energy Consumption per Year 32 kWh
Power Consumption (On mode) 22 W
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.265 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Colour Support 16.8 million colours
Input Connectors HDMI, DVI-D, VGA
Speakers Integrated
Display Position Adjustments Swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 53.25 cm x 23 cm x 38.6 cm
Weight 5.4 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards PSE Mark, Green Mark, J-MOSS, TUV Bauart, VCCI Class B
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLiteXUB2390H...
£127.71
