iiyama T1532SR-W1 15" 1024x768 16ms VGA DVI USB Monitor
£365.48
Delivery:
Product codes
ProLite T1532SR is an incredibly powerful touch solution based on the latest 5 Wire Resistive technology. Price / performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both Analog and Digital (DVI) with Touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the touch screen with an adjustable stand offering full 90 degree positioning angles. Extensive Touch Utilities allow for 4 point calibration and 9/25 point linerization. Menu buttons are located on the side of the screen which can be locked to prevent tampering, and includes a handy function to deactivate the Touch Screen for cleaning. In addition the bezel free design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
iiyama ProLite T1532SR-W1 - LCD monitor - 15"
LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
200 cd/m²
Contrast Ratio
500:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
White
35.1 cm x 20.1 cm x 30.6 cm
4.8 kg
VCCI, DDC-2B, VESA DPMS, CB, GOST-R, IP54, TUV Bauart
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama T1532SR-W1 15"...
£365.48
