iiyama T1931SR-B1 19" 1280x1024 5ms DVI-D VGA Touch Scre...
iiyama T1931SR-B1 19" 1280x1024 5ms DVI-D VGA Touch Screen Monitor with Speakers
Key features
  • Touch technology
  • Cable management system
  • RS-232 and USB connectivity
Product codes
ProLite T1931SR-1 is based on the 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90-degree angles. Extensive touch utilities allow for 4-point calibration and either 9/25 point linearization.
iiyama ProLite T1931SR-B1 - LCD monitor - 19"
LCD monitor - 19" - touchscreen
Touch-screen, stereo speakers
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
200 cd/m²
Contrast Ratio
900:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
43.1 cm x 39.1 cm x 21.8 cm
6.5 kg
Plug and Play, FCC Class B certified, UL, TUV, VCCI Class B ITE, cUL
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama T1931SR-B1 19"...
