General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class A |
Energy Consumption per Year |
35 kWh |
Power Consumption (On mode) |
24.1 W |
Diagonal Size |
24" |
Viewable Size |
23.6" |
Built-in Devices |
Microphone, camera, USB 2.0 hub |
Panel Type |
VA |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 |
Pixel Pitch |
0.272 mm |
Brightness |
250 cd/m² |
Brightness w/touchscreen |
215 cd/m² |
Contrast Ratio |
3000:1 / 12000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Response Time |
6 ms |
Vertical Refresh Rate |
55 - 75 Hz |
Horizontal Refresh Rate |
30 - 80 kHz |
Horizontal Viewing Angle |
+89 / -89 |
Vertical Viewing Angle |
+89 / -89 |
Screen Coating |
7H Hard Coating |
Backlight Technology |
LED backlight |
OSD Languages |
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese |
Features |
Eco-Mode, HID Compliant, X-Res Technology, 10-point multi-touch, blue light reduction, i-Style Color |
Colour |
Black |
Dimensions (WxDxH) |
57.1 cm x 4.45 cm x 34.75 cm |
Weight |
6.2 kg |
Audio |
Type |
Speakers - stereo |
Output Power / Channel |
1 Watt |
Input |
Type |
Touch-screen - touchscreen |
Movement Detection Technology |
Projected capacitive |
Connectivity |
Interfaces |
DVI-D , DisplayPort , HDMI , Headphones , Audio line-in , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , USB 2.0 (Type B) |
Mechanical |
Display Position Adjustments |
Tilt |
Tilt Angle |
+15/+70 |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately), built-in adjustable tilt stand |
Cables Included |
1 x DVI cable - DVI-D to DVI-D , 1 x Mini DisplayPort-DisplayPort cable , 1 x audio cable , 1 x USB cable |
Compliant Standards |
VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B |
Security Slot Type |
Kensington security slot |
Power |
Voltage Required |
AC 100/240 V (50/60 Hz) |
Power Consumption Operational |
23 Watt |
Power Consumption Stand by |
0.5 Watt |
Software / System Requirements |
Included Software |
Driver |
OS Required |
Linux, Microsoft Windows Vista, Microsoft Windows 7 / Windows 8 |
