The XB2472HSUC-B1 is an advanced desktop monitor for demanding users looking for a high-quality. The VA matrix offers wide viewing angles and sharp contrast. The blue light reducer function with flicker-free LCD technology reduces eye strain and offers a more comfortable viewing experience.
Product Description | iiyama ProLite XB2472HSUC-B1 - LED monitor - Full HD (1080p) - 23.6" | Device Type | LED-backlit LCD monitor - 23.6" | Features | Microphone, 2.0 megapixel camera, USB 2.0 hub | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.2715 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 12000000:1 (dynamic) | Response Time | 8 ms | Colour Support | 16.7 million colours | Input Connectors | DVI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Black | Dimensions (WxDxH) | 55.7 cm x 23 cm x 40.65 cm | Weight | 5.8 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | DDC-2B, VESA DPMS, TUV Bauart, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.6" |
Built-in Devices | Microphone, 2.0 megapixel camera, USB 2.0 hub |
Panel Type | VA |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 30 - 94 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch |
Features | Eco-Mode, matte, X-Res Technology, Flicker Free technology, i-Style Color, Blue Light Filter technology |
Colour | Black |
Weight | 5.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI (HDCP) , HDMI (HDCP) , Audio line-out , USB 2.0 upstream , 2 x USB 2.0 downstream |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable , 1 x USB cable |
Power | |
Voltage Required | AC 120/230 V (50 - 60 Hz) |
Power Consumption Operational | 21.5 Watt |
Environmental Standards | |
ENERGY STAR Certified | Yes |
