General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class B |
Energy Consumption per Year |
37 kWh |
Power Consumption (On mode) |
25.5 W |
Diagonal Size |
24" |
Viewable Size |
23.6" |
Built-in Devices |
Stereo speakers |
Panel Type |
VA |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 |
Pixel Pitch |
0.2715 mm |
Brightness |
250 cd/m² |
Contrast Ratio |
3000:1 / 12000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Response Time |
6 ms |
Vertical Refresh Rate |
56 - 75 Hz |
Horizontal Refresh Rate |
24 - 80 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Backlight Technology |
LED backlight |
Controls & Adjustments |
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control, luminance |
OSD Languages |
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese |
Features |
Cable management cover, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), i-Style Color |
Colour |
Black |
Dimensions (WxDxH) |
54.35 cm x 23 cm x 40.7 cm - with stand |
Weight |
5.5 kg |
Audio |
Type |
Speakers - stereo - integrated |
Output Power / Channel |
2 Watt |
Connectivity |
Interfaces |
DVI-D , VGA , HDMI , Audio line-in |
Mechanical |
Display Position Adjustments |
Height, pivot (rotation), swivel, tilt |
Tilt Angle |
-5/+22 |
Swivel Angle |
320 |
Rotation Angle |
90 |
Height Adjustment |
130 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately) |
Cables Included |
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable |
Compliant Standards |
TUV GS, DDC-2B, VESA DPMS, ISO 9241-307 |
Power |
Power Supply |
Internal |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
25 Watt |
On / Off Switch |
Yes |
Software / System Requirements |
Included Software |
Driver |
OS Required |
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8 |
Environmental Standards |
ENERGY STAR Certified |
Yes |
