The Intel compute stick is a tiny device that can transform any HDMI TV or display into a complete computer. But what's inside is really incredible: an advanced processor for the performance you need to create brilliant presentations with graphics, create analytics models on a spreadsheet, or drive 4K digital signage. Just plug in the Intel compute stick into HDMI TV or monitor, connect your wireless keyboard and mouse and you're ready to go.
Intel® Core™ M Processor
Mobile computing without compromise
Thin, light, quiet and versatile. The new 6th generation Intel® Core™ processors built on 14 nm manufacturing process technology deliver great mobile performance, blazing-fast responsiveness and amazing battery life. This feature packed processor with built-in security is ready to take your productivity, creativity and entertainment to the next level. And, by enabling the exciting Windows® 10 features, 6th generation Intel® Core™ m3/m5/m7 processors empower you to unleash your imagination and explore the possibilities.1 2
By modernising your business with 6th generation Intel® Core™ M series vPro™ processor-based mobile devices, you can be confident they'll be ready for Windows® 10 when it's time to migrate. It's simply a better way to work.
Intel Compute Stick Productivity Usage Guide
By allowing you to transform any HDMI* display into a fully functional computer, the Intel® Compute Stick lets you stay productive anywhere you have an HDMI display. Ready to go out of the box, this new type of computing device has a quad-core Intel® Atom™ processor and offers the performance, quality, and value you expect from Intel. The system performs just like your other computers -- simply plug it into any HDMI monitor or TV, connect a wireless keyboard and mouse, and you can work when, where, and how you want. It's everything you love about your desktop computer in a device that fits in the palm of your hand.
Intel® Compute Stick Digital Signage Usage Guide
A new type of computing device, the Intel® Compute Stick enables you to transform a display into a fully functional digital signage solution via the display's HDMI* port. Ready to go out of the box, the Intel Compute Stick has a quad-core Intel® Atom™ processor and offers the performance, quality, and value you expect from Intel. The system performs just like your other computers. Simply plug it into any HDMI monitor, connect to the cloud for your data or access files locally, and you've got a simple digital sign or a point-of-sale (POS) display.
Intel® Compute Stick Thin Client Usage Guide
A new type of computing device that lets you compute in small spaces, the Intel® Compute Stick enables you to transform a display into a thin-client platform via an HDMI* port. Ready to go out of the box, the Intel Compute Stick has a quad-core Intel® Atom™ processor and offers the performance, quality, and value you expect from Intel. The system performs just like your other computers -- simply plug it into any HDMI display, connect your wireless keyboard and mouse, and you're ready to connect and collaborate in call centers, computer labs, or anywhere you're working.
Product Description | Intel Compute Stick STK2m3W64CC - stick - Core m3 6Y30 1.6 GHz - 4 GB - 64 GB | Type | Personal computer - stick | Processor | 1 x Intel Core m3 (6th Gen) 6Y30 / 1.6 GHz (Dual-Core) | Cache Memory | 3 MB L3 Cache | Cache Per Processor | 3 MB | RAM | 4 GB (installed) / 4 GB (max) - LPDDR3 SDRAM | Hard Drive | 1 x flash 64 GB - eMMC | Optical Storage | No optical drive | Card Reader | Yes | Graphics Controller | Intel HD Graphics | Networking | 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.1 | OS Provided | Windows 10 Home 64-bit Edition | Colour | Black | Dimensions (WxDxH) | 3.5 cm x 11.4 cm x 1.1 cm | Manufacturer Warranty | Limited warranty - 3 years |
General | |
Type | Personal computer |
Product Form Factor | Stick |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core m3 (6th Gen) 6Y30 / 1.6 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Not upgradable |
Cache Memory | |
Installed Size | L3 Cache - 3 MB |
RAM | |
Installed Size | 4 GB / 4 GB (max) |
Technology | LPDDR3 SDRAM |
Effective Memory Speed | 1866 MHz |
Features | Dual channel memory architecture |
Configuration Features | Provided memory is soldered |
Hard Drive | |
Type | Flash - eMMC |
Capacity | 1 x 64 GB |
Optical Storage | |
Type | No optical drive |
Card Reader | |
Type | Card reader |
Supported Flash Memory Cards | microSDXC UHS-I Memory Card |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics |
Video Interfaces | HDMI |
Audio Output | |
Compliant Standards | High Definition Audio |
Networking | |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 8260 |
Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1 |
Expansion / Connectivity | |
Interfaces | 1 x USB 3.0 , 1 x HDMI |
Miscellaneous | |
Quantity of Items per Pack | 5 |
Cables Included | SuperSpeed USB-C cable , HDMI extension cable |
Theft/Intrusion Protection | Padlock loop |
Power | |
Device Type | Power adapter |
Operating System / Software | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight | |
Width | 3.5 cm |
Depth | 11.4 cm |
Height | 1.1 cm |
