Intel Gigabit CT Desktop PCI Express Network Adapter
£37.24
29 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Delivers increased performance while significantly reducing CPU usage
  • Reduces deployment and training costs and enables easy, quick migration to Gigabit Ethernet
  • Automatically compatible with Ethernet, fast Ethernet, and Gigabit Ethernet networks
  • Enables widespread deployment
  • Allows low-power consumption, remote wake, and remote booting
  • Reduces support costs with remote management based on industry-wide standards
  • Provides point-and-click power over individual adapters, advanced adapter features, connection teaming, and virtual local area network (VLAN) configuration
  • Dynamically tests and reports network problems (error rate, cable length) and automatically compensates for cable issues
  • Efficient packet prioritization
  • Minimizes the overhead of interrupts
  • Allows load balancing of interrupt handling between different cores/CPUs
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Form Factor: Plug-in card
  • Compatibility: PC
  • Type: Network adapter
Product codes
For PCs with PCI Express (PCIe) slots, the Intel Gigabit CT Desktop Adapter offers the newest technology for maximizing system performance and increasing end-user productivity. Specifically, the Intel Gigabit CT Desktop Adapter uses auto- negotiation to ensure the adapter runs at the highest available network speed (10, 100, or 1000 Mbps), and maintains full bandwidth capacity with the dedicated bandwidth of a PCIe input/output (I/O) bus to provide connectivity you can count on. Based on the low-power Intel 82574L Gigabit Ethernet Controller, this desktop adapter offers optimal performance in a low-cost, low-power, compact profile. Teaming support and an array of other advanced features enable customers to use this adapter as an entry-level server adapter as well.
Intel Ethernet - It Just Works!
Product Description Intel Gigabit CT Desktop Adapter - network adapter
Device Type Network adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
PCI Specification Revision PCIe 1.1
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1000 Mbps
Processor 1 x 82574L - Intel
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Intel Gigabit CT Deskt...
£37.24
