Intel Next Unit of Computing - Barebone Mini PC Celeron J3455
£120.13
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Up to 7.1 surround audio via HDMI
  • Headphone/microphone jack on the front panel
  • Dual array front mics on the chassis front
  • combo speaker/TOSLINK optical audio jack on the back panel
  • SuperSpeed USB 3.0 ports
  • Hi-Speed USB 2.0 ports via internal header
  • SDXC slot with UHS-I support on the side
  • Multi-country plugs
  • Support for user-replaceable third-party lids
  • Intel Visual BIOS
  • Intel Express BIOS update support
  • Fan sensor inputs used to monitor fan activity
  • ACPI-compliant power management control
  • HDD LED, power LED, power on/off
  • Multi-color selectable-front panel LED ring
  • Kensington lock with base security
Product codes
Bundle deals (1)
TPLINK 25W 5-PORT USB CHARGER
Intel Next Unit of Computing - Barebone Mini PC Celeron...
£119.26
= £132.26
Save £3.00
  • Superior processing and graphics
    Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics.
  • Stunningly small form factor
    The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations.
  • Advanced technology
    The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
Intel NUC Kit NUC6CAYH built with a quad-core Intel Celeron processor, delivers cost-efficient Intel-level performance in a fully customizable kit that makes it perfect for basic 4K digital signage, PC replacement, or thin client. This kit gives you the choice to install the OS, memory, and hard drive you want so you can create the exact system that you need. The features include a dual-array front mic and a multi-color LED ring so you can customize your NUC with the look you want. And there's 4K display support via a full-sized HDMI 2.0 port, so you can have 4K digital signs at a cost-effective price point.
Intel Next Unit of Computing Kit NUC6CAYH - mini PC - Celeron J3455 1.5 GHz - 0 MB
PC barebone - mini PC
1 x Intel Celeron J3455 / 1.5 GHz (2.3 GHz) (Quad-Core)
Processor Main Features
Intel Virtualization Technology, Intel AES New Instructions
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
0 MB (installed) / 8 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel HD Graphics 500
Audio Output
7.1 channel surround
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
11.5 cm x 11.1 cm x 5.1 cm
Limited warranty - 3 years
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Intel Next Unit of Com...
£120.13
