Intel X540-T2 Bulk Ethernet Converged Network Adapter
£524.71
Delivery:
Key features
  • Low cost, low power, 10 Gigabit Ethernet (10GbE) performance for the entire data center
  • Standard CAT-6a cabling with RJ45 connectors
  • Backward compatibility with existing 1000Base-T networks simplifies the transition to 10GbE
  • Flexible I/O virtualization for port partitioning and quality of service (QoS) of up to 64 virtual ports
  • Unified networking delivering LAN, iSCSI, and FCoE in one low cost CNA
  • Industry first dual-port 10GBase-T adapter with single-chip solution with integrated MAC + PHY
Product codes
The Intel X540 family of products works with existing networks today. It works with legacy Gigabit Ethernet (GbE) switches and Cat 6A cabling. Install the Intel X540 adapter into a server and the auto-negotiation between 1GbE and 10GbE provides the necessary backwards compatibility that most customers require for a smooth transition and easy migration to 10GbE. When time and budget allows, 10GBase-T switches can be added any time to experience the full benefits of 10GbE.
The Intel Ethernet Converged Network Adapter X540 is the low cost way to deploy 10GbE in your data center today. The Intel X540 uses low cost, Cat 6 and Cat 6A cabling. Chances are this cabling already exists in the data center. A way for Intel to reduce cost and power is to integrate components into a single-chip solution. Of course, integration is what Intel does best. With the Intel X540 controller, the MAC and the PHY are integrated into a single-chip solution. With lower cost and power, 10GBase-T is ready for broad deployment. 10GBase-T is an option for every rack and tower server in the data center. The wait for a low cost 10GbE copper solution to broadly deploy 10GbE to all corners of the data center is over. The Intel X540 adapter provides bandwidth-intensive applications with highly affordable 10GbE network performance and cost-effective RJ-45 connectivity for distances up to 100 meters.
Product Description Intel Ethernet Converged Network Adapter X540-T2 - network adapter
Device Type Network adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express 2.1 x8
PCI Specification Revision PCIe 2.1
Ports 10Gb Ethernet x 2
Cabling Type Ethernet 10GBase-T
Data Link Protocol 10 GigE
Data Transfer Rate 10 Gbps
Network / Transport Protocol TCP/IP, UDP/IP, IPSec, iSCSI
Compliant Standards IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP)
System Requirements Microsoft Windows 7, Linux 2.6.x, SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 SP2, Microsoft Windows Vista SP2, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2003 SP2, Red Hat Enterprise Linux 6, VMware ESXi, Windows 8, Microsoft Windows Server 2012, VMware ESX, Linux 3.x, FreeBSD 9
Microsoft Certification Compatible with Windows 7
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Intel X540-T2 Bulk Eth...
£524.71
