Jabra BIZ 1500 Duo NC Headset
£50.89
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Great sound, with noise-cancelling microphone and HD Voice to deliver professional sounding calls
  • Robust, entry-level design that is easy to use, with all essential features
  • All-day comfort, with foam cushions to keep ears cool and a flexible boom-arm that safely rotates 270 degrees
  • Easy to use right out of the box
  • Quick disconnect version for easy deskphone connectivity
  • Noise-cancelling microphones reduce unwanted background noise and are ideal in crowded and noisy open working environments
  • Digital Signal Processing (DSP) reduces background noise and removes echo
  • Enjoy high-definition sound with HD Voice and get crystal-clear communication
  • Jabra Spin Boom Arm with 270¢ª degree boom arm for easy adjustment without breaking
  • Customize your settings with Jabra¡¯s software applications
  • Recommended Use: Phone, Phone
  • Connectivity: Wired
  • Earcover : Binaural
  • Stock Status: In Stock
Product codes
The Jabra BIZ 1500 is an entry level, low-cost, professional corded headset with Jabra’s leading noise-cancellation technology. Designed for comfortable all-day wear.
Great sound
  • Noise-cancelling Air Shock microphone reduces background noise and sharp breathing sounds – ideal for crowded open offices.
  • HD Voice makes your conversations sound vibrant and lifelike.
All-day comfort
  • Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears.
  • Headband and microphone boom can be adjusted to suit your preference.
Tough Design
  • Built to survive in a high-performing contact centre, with a boom-arm that can be rotated 270 degrees without the risk of breaking
Product Description Jabra BIZ 1500 Duo - headset
Product Type Headset - wired - Quick Disconnect
Recommended Use Phone
Localisation EMEA
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 4500 Hz - Sensitivity 115.5 dB/mW
Impedance 150 Ohm
Max Input Power 30 mW
Microphone Boom
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra BIZ 1500 Duo NC...
£50.89
