Jabra BIZ 1500 Duo USB Wideband Headset
£69.61
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Customize your settings with Jabra¡¯s software applications
  • Digital Signal Processing (DSP) reduces background noise and removes echo
  • Enjoy high-definition sound with HD Voice and get crystal-clear communication
  • Jabra Spin Boom Arm with 270¢ª degree boom arm for easy adjustment without breaking
  • Noise-cancelling microphones reduce unwanted background noise and are ideal in crowded and noisy open working environments
Product codes
Jabra BIZ 1500 Duo USB headset is a professional grade entry level USB Computer headsets with excellent value for call centers. It comes complete with a USB plug for instant plug-and-play computer connection, letting you benefit from its clear sound and low cost of ownership. Equipped with a noise-cancelling microphone and HD quality sound. Its light weight headband provide all day comfort for your call-intensive office.
Great sound
  • Noise-cancelling Air Shock microphone reduces background noise and sharp breathing sounds – ideal for crowded open offices.
  • HD Voice makes your conversations sound vibrant and lifelike.
All-day comfort
  • Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears.
  • Headband and microphone boom can be adjusted to suit your preference.
Tough Design
  • Built to survive in a high-performing contact centre, with a boom-arm that can be rotated 270 degrees without the risk of breaking.
Jabra BIZ 1500 Duo - headset
Headset - wired - USB
Recommended Use
Phone
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 4500 Hz - Sensitivity 115.5 dB/mW
Impedance
150 Ohm
Max Input Power
30 mW
Microphone
Boom
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra BIZ 1500 Duo USB...
£69.61
