Jabra BIZ 2300 Duo USB Headset
£127.38
Delivery:
Key features
  • Boom arm can be rotated 360 degrees with zero risk of breaking
  • HD voice technology makes sure you clearly understand the other party
  • Kevlar -reinforced cord is built to withstand the contact center environment and is protected against office chair wheels, sharp objects and daily use
  • Specially designed "air shock" noise cancelling mic filters out sharp breathing sounds and popping noises often heard in conversations
Product codes
Documents
Better conversations for the contact centre
Your contact centre agents are your brand's front line. Jabra BIZ 2300 will ensure every customer conversation becomes a great brand experience. This new corded headset features HD Voice/Wideband speaker performance and best-in-class noise-cancellation.
Keep your contact centre agents happy
The Jabra BIZ 2300 for contact centres blends a lightweight yet durable construction with an unobtrusive, professional Scandinavian design aesthetic. The Jabra BIZ 2300 works hard, looks great and is designed for easy daily handling. It is a headset built to be comfortable all day long.
The contact centre headset that is built to last
Jabra BIZ 2300 is built with total cost of ownership in mind. Beside 360° degree rotating break-proof boom-arm and Kevlar-reinforced cord, the Jabra BIZ 2300 is built to withstand any punishment a high-performing contact centre can give.
A UC headset with easy in-line call management
The Jabra BIZ 2300 is a UC headset that features an intuitive, in-line call controller for greater productivity and convenience. Large buttons with LED indicators make it easy for agents to pick up or end calls, put callers on or take them off hold, set volume levels or put the call on mute. Plus, all buttons are user-programmable.
Product Description Jabra BIZ 2300 USB UC Duo - headset
Product Type Headset - wired - USB
Recommended Use Computer - communication
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Stereo
Audio Specifications Frequency Response 70 - 16000 Hz - Sensitivity 93 dB
Impedance 32 Ohm
Max Input Power 10 mW
Microphone Boom
Microphone Active Noise Cancelling Yes
Controls Mute, volume, answer/end, hold, programmable button
Resources
The following resources are available for the Jabra BIZ 2300 Duo USB Headset
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra BIZ 2300 Duo USB...
£127.38
