Jabra BIZ 2400 II 3-in-1 Duo IP Headset top only
£155.68
Delivery:
Key features
  • Multi-device connectivity allows you to purchase a variety of different cords that let you connect to your smartphone or deskphone
  • Noise-cancelling microphones reduce unwanted background noise and are ideal in crowded and noisy open working environments
  • PeakStop instantly removes any harmful loud sounds before they even reach your ears
  • Reinforced cords are built to last
  • With FreeSpin you can rotate the boom-arm 360 degrees without the risk of it breaking
  • Recommended Use: Phone, Phone
  • Connectivity: Wired
  • Earcover : Binaural
Product codes
The BIZ 2400 II offers outstanding sound at both ends of the call for a superior customer experience, a corded professional headset that delivers outstanding sound on both ends of the call. Up to 40% lighter than competing headsets and with a low pressure, super-soft leatherette headband, the Biz 2400 II allows the agent to focus on their customer conversation in unrivalled comfort.
Better conversation
The most important function of a contact centre headset is eliminating background noise from the busy environment and letting the customer hear your voice clearly. The ultra-noise-cancelling microphone provides the highest degree of background noise elimination in any of our headsets.
Jabra BIZ 2400 II QD Duo is a duo headset with a QD (Quick Disconnect) plug that provides instant connectivity to a wide range of desk phone systems.
Product Description Jabra BIZ 2400 II QD Duo NC Wideband - headset
Product Type Headset - wired - Quick Disconnect
Recommended Use Phone - communication
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Stereo
Audio Specifications Frequency Response 100 - 6500 Hz
Max Input Power 20 mW
Microphone Boom
Microphone Active Noise Cancelling Yes
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra BIZ 2400 II 3-in...
£155.68
