Jabra Evolve 20 Duo UC USB Headset
£39.34
Delivery:
Key features
  • Flexible connectivity using USB or jack
  • Manage calls easily with call control unit to make, take and mute calls
  • Plug-and-play connectivity for quick and easy set-up
  • Leather-feel ear cushions and around-the-ear design for all-day use
  • Works with all leading UC platforms and certified for Skype for Business, Cisco and more
  • Stay focused by eliminating distraction in noisy open office environments
Product codes
Professional headset with easy call management and great sound for calls and music!
More than headsets, a workplace evolution
With great sound for calls and music, the Evolve 20 and 20 Special Edition are entry-level professional headsets with easy call management through a control unit that makes, takes and mutes calls. Simple connectivity makes it easy to get started with your PC.
Clearer conversation for greater efficiency
Entry-level professional headset with easy call management and great sound for calls and music.
Manage calls easily
Get easy access to the most used functions, like volume and mute. You can also answer and end calls quickly and easily, directly from the control unit.
Flexible Plug and Play connectivity
Works straight out of the box. Installation is as easy as simply plugging it in to the USB port on your laptop.
All day comfort (Evolve 20SE)
Built for style and comfort with soft leatherette ear cushions. Adjustable headband lets you find the perfect fit.
Product Description Jabra Evolve 20 UC stereo - headset
Product Type Headset - wired - USB
Recommended Use Computer - communication
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Stereo
Sound Effects Crystal Clear
Audio Specifications Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
Impedance 32 Ohm
Max Input Power 5 mW
Microphone Boom
Microphone Technology Electret condenser
Controls Mute, volume, answer/end
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra Evolve 20 Duo UC...
£39.34
